Most people no longer use CDs and DVDs due to the digital revolution. Folks want to have their music on their computer or mobile device, and a CD is no viable way to store audio content in today’s age. If, for some reason, you have multiple CDs or DVDs lying around with music or any other audio content on them, then maybe it’s time to rip them to your Windows computer and throw the CDs into the trash.
Any Audio Grabber for Windows PC
You might wonder if it’s easy to rip audio files from physical media. We have to answer that question with a resounding yes. Windows makes it very easy to rip audio files from physical media, but today, we won’t talk about Windows’ built-in audio ripper software. Instead, we will focus on Any Audio Grabber, a decent CD ripper that works better than expected.
The user interface is simple
After installing Any Audio Grabber and launching it, users will come across a modern user interface. The only thing users are required to do when ripping CDs is to select the disc from the section that says “Please select CD drive, and from there, the software should do the rest.
Once all the tracks are listed, users can play them by using the available playback controls on the menu.
Different grabbing options
By pressing Next, you should see a box supporting multiple grabbing options. If a single grabbing option is not your thing, then you may find Any Audio Grabber as the next best thing. You see, it supports grabbing modes in Burst: fast no error correction, Synch: correct jitter errors and Secure: double precision error correction.
It also supports file formats such as MP3, AAC, MP2, ADPCM, AMR, M4A, WAV, and OGG.
The advanced section has filtering and VBR support, so there’s much to do here, but it doesn’t overwhelm users.
Change media location and fire off to the end
The third step brings users to where they can change the media location and create artiste and album name folders. This section also describes the amount of space on the hard drive and the space required to save the audio content.
The final step is to click on Start and go ahead to wash the dishes or whatever else you need to do because the speed depends on your computer’s performance.
Overall, we like What Any Audio Grabber brings to the market. It’s easy to use and requires few complications to get the job done. Click next, choose your options, and click next again until the task is complete.
That’s how folks should make a CD and DVD ripper, one that is designed for everybody. Download Any Audio Grabber here. Works on Windows 11 and Windows 10.
