Battlefield 2042 is one game that’s filled with a lot of errors. The game is being played and loved by many, however, this can not hide the fact that a big chunk of those players and lovers get unhappy from time to time because of random issues. As of late, a lot of gamers are complaining that Battlefield 2042 settings keep resetting are not saving and they want an instant fix. Well, in this article, we are going to talk about just that and see what you can do to resolve the issue.
Battlefield 2042 Settings keep resetting and not saving
If Battlefield 2042 Settings keep resetting and are not saving, then here are some suggestions to fix the problem for you on your Windows 11/10 PC.
- Allow the game through Firewall
- Run Battlefield 2042 as an administrator
- Delete Temporary Files
- Verify the integrity of game files
- Troubleshoot in Clean Boot
1] Allow the game through Firewall
Windows Defender Firewall or a third-party antivirus can block some functioning of your game and as a result, chances are your Battlefield 2042 settings won’t save. What you need to do is allow the game through the Windows Firewall. If you are using a third-party antivirus, then try whitelisting it, hopefully, this will do the job for you.
2] Run Battlefield 2042 as an administrator
If Battlefield 2042 is not launching as an administrator, it won’t get the privileges required to create folders and save files on your computer. What you need to do is either open the launcher aka Steam as an administrator or change the settings of the Launcher such that it will launch with the required permissions. To just open the game in elevated mode, just right-click on the Launcher and click Run as administrator.
You can also change the settings to always open Battlefield 2042 as an administrator. Follow the given steps to do the same.
- Right-click on Steam and select Properties.
- Go to the Compatibility tab.
- Tick Run the program as an administrator and click Apply > Ok.
3] Delete Temporary Files
Sometimes, the previously saved game files get corrupted, which as a result will stop the new files from forming. We need to remove the temporary file or at least rename it (for backup). So, open File Explorer, go to Documents, and then to Battlefield 2042. Now, open the Settings folder, right-click on PROFSAVE_tmp, select Rename, and remove “_tmp”.
Finally, restart the computer and the game. Hopefully, it will do the job for you.
4] Verify the integrity of game files
Usually, corrupted files will stop the game from launching on your computer, but sometimes, they do trigger these peculiar issues. You can use the launcher to scan and repair the files. Follow the given steps to do the same.
- Open Steam.
- Go to LIBRARY.
- Right-click on the game and click Properties.
- Go to the LOCAL FILES tab and click VERIFY THE INTEGRITY OF GAME FILES.
Wait for the process to complete, as it will scan and repair your game.
5] Troubleshoot in Clean Boot
If a third-party application such as OneDrive is interfering with your game, issues such as the one in question will be triggered. We need to perform Clean Boot and find out what is causing the issue. Once you know what is causing the problem, just delete it and your issue will be resolved.
Hopefully, these solutions will be resolved with the solutions that we have mentioned earlier.
Read: Fix Battlefield 2042 DirectX Errors
Are they fixing Battlefield 2042?
As mentioned earlier, Battlefield 2042 has a lot of errors. The game has been crashing, freezing, experiencing FPS Drops, etc, however, this doesn’t mean that developers are not updating the game. They are releasing game patches to resolve these issues. You sometimes wouldn’t know, but the Steam installs latest patches of your game. So, yes, they are trying to fix the game, hopefully, the game will be perfectly refined in some time.
Read: Battlefield 2042 keeps crashing or freezing on PC
Is BF2042 a failure?
Battlefield 2042 is released amidst Covid 19, which throttle the sales a bit. According to some sources, EA has admitted that the game has failed to meet the expectations of the players. However, one can not just blame covid for the failure, there are a ton of issues in BF2042, and that has made a dent in the sales and reviews of the game.
But we can expect that post-covid and post-error-fixing the game will see an upsurge in downloads.
Also Read: Fix Battlefield 2042 Launch Error 0xC0020015.
