Sound Blaster is a well-known hardware company that has been around for more than two decades, delivering high-quality sound cards. If you are using a Windows 10 PC with their hardware, then there are two apps—Sound Blaster Command and Sound Blaster Cinema —that can enhance your audio experience. You can configure and personalize the audio settings of Sound Blaster Card using these apps.
Change audio settings of Sound Blaster Card
You should know that this software works on specific hardware and is not available for all Sound Blaster devices. So, make sure to check if you have the specific hardware. However, you can always try to see if it supports it.
1] Sound Blaster Command
Sound Blaster Command lets you easily configure and personalize the audio settings. You can create SBX Profiles for movies, games, and any other application that offers an audio experience. The app allows you to manage
- Surround sound
- Crystallizer
- Bass
- Smart volume
- Dialog enhancement, and more.
- Then you can setup equalizer profiles, configure playback for speaker or headphones, change recording voice, and so on.
The audio changing part is interesting. You can morph your voice as male, female, kid, elderly, deep voice, emo, elf, dwarf, robot, or anything else. When you are recording a voice-over or talking to someone using a software, then you can use it to hide your original voice.
Download it from the Microsoft Store. It works with Sound Blaster MB7.
2] Sound Blaster Cinema
Similar to Sound Blaster Command, you can configure and personalize your Creative product’s audio settings. You can set this for a different sound experience where it can have its equalizer settings, SBX pro studio settings with smart volume, and dialogue configuration. There are predefined settings for gaming, movies, music, and streaming.
Smart volume is one of the key features. It automatically adjusts the loudness of the speaker’s voice to maintain a consistent volume level. So, when you record audio with speakers at different locations, it will adjust to make them appear to be coming from the same location.
Download it from the Microsoft Store. It works with Cinema 6 Sound Card.
Let us know if you find them useful.
