When using Excel application, you may receive an error saying Excel cannot complete this task, Out of Memory or Not enough System Resources to Display Completely condition. In this post, we are offering how you can resolve this problem and continue to use the Excel File.
Fix Excel Out of Memory error
Here is the list of errors that can show up under this situation:
- Excel cannot complete this task with available resources. Choose less data or close other applications.
- Out of Memory
- Not enough System Resources to Display Completely
- There isn’t enough memory to complete this action. Try using less data or closing other applications. To increase memory availability, consider:
- Using a 64-bit version of Microsoft Excel.
- Adding memory to your device.
There isn’t enough memory to complete this action Excel error
It is important to note that the error message is general, but one thing is clear that the Excel app is not able to process large file sizes. The file is so huge that it consumes the whole memory available to the system. If your Excel file is large or has a lot of formulas and scripts, the system may run low on memory. That said, Microsoft has officially shared some limitations for Excel.
- Excel: Specifications and limits
- Excel Performance: Performance and Limit Improvements
- Excel: Memory usage in the 32-bit edition
Keeping this in mind, let us know how we can resolve the error message.
- Install Updates
- File Specific Issue
- Interfering Add-ins
- Test with the 64-bit version of Excel
- Add Physical RAM
- Change the default Printer
- Test without Antivirus
It is apparent that you need more memory. You may look at the other applications that are consuming the memory and get rid of them. You can terminate such applications, and stop them from running in the background.
Similar: Not enough memory to run Microsoft Excel
Not enough System Resources to Display Completely Excel error
1] Install Updates
Sometimes, it could be because of a previous update, or Microsoft has released an update to handle these kinds of situations. I highly recommend that you check for any updates for your OS and Office software and install them before following any further suggestions.
2] File Specific Issue
If the error occurs for only one file, you may need to revisit its content. It could be because copy-paste involves a high number of calculations, such as cells, complex PivotTables, macros, complex charts with many data points, custom views, and so on.
You need to manually check it by opening it in Protected View, disabling VPA features, and so on. Remember, the error will not occur when you open a file, but it will happen when it performs a heavy calculation or when you insert new data beyond Excel’s capacity.
You may also want to break the Excel file into smaller files to handle the situation more effectively.
3] Interfering Add-ins
If you have plugins or add-ins installed in Excel, it would be a good idea to disable and check if you still face the issue. If you do not face any problem, then you need to check if there is an update for the add-in available. Sometimes Add-ins take a high amount of resources to complete a task, which results in Out of Memory, Not enough System Resources to Display Completely problem.
4] Try with the 64-bit version of Excel
A 64-bit version of Microsoft Office can handle large files better than the 32 bit Excel application. It is because there is a limit of 2 GB for any 32-bit application. If you need to handle large files almost every day, it is better to download or move to Microsoft Excel 64 bit version. It will be able to access more RAM and get things done faster without resulting in Out of Memory issue.
5] Add more physical memory to your computer
If it is the physical memory you are running out of, then its time you add more RAM to your computer. If you are switching to a 64-bit version, then adding extra memory will help you process the Excel file a lot faster.
6] Change the default Printer
When Excel launches, it polls for the default printer. At times, it may get stuck with if the printer is not available or doesn’t respond because the data is too much to handle. We will recommend you to change your default printer to one of the virtual printers available on the computer such as PDF printer or XPS document writer.
- Open Windows Settings (WIn + I)
- Navigate to Devices > Printers and Scanners
- Uncheck the box which says Let Windows manage my default printer
- Select one of the virtual printers, and click on Manage button
- Click on Set as default button under Manage your device section
Try again, and see if it works fine this time.
7] Temporarily disable Antivirus
Antivirus software is known to cause these types of problems, especially if they end up scanning the file again and again. It can be a false positive as well if the antivirus things the file can harm the computer. Most of antivirus offer a temporary disable option. So try again after doing that or completely uninstall the AV to check if the issue is resolved.
Let us know if anything here helped you.
How do I free up memory in Excel?
To free up memory in Excel, optimize your file by removing unnecessary data, using more efficient formulas, and reducing the size of images and charts. You can use the ‘Save As’ feature to compress the file size.
How to fix Excel cannot complete this task with available resources?
To fix the “Excel cannot complete this task with available resources” error, close unnecessary programs to free up memory, increase Excel’s allocated memory through Windows settings, and reduce the number of open Excel files or complex formulas.
How do I fix Excel Not enough system resources to display completely?
To fix the Not enough system resources to display completely error in Excel, try closing unused applications to free up memory. Also, increase Excel’s allocated memory in settings, disable add-ins that might consume resources, and update Excel to the latest version for performance improvements.
How to fix Excel error Excel ran out of resources?
To fix the “Excel ran out of resources” error, try closing unused applications and Excel workbooks, increasing system RAM, and checking for large formulas or data sets. You can also adjust Excel’s settings to use less memory resources.
