Apex Legends is one of the most popular games in the PC gaming industry. However, it is filled with errors and in this article, we are going to talk about one of them. According to many gamers, the game either crashes or fails to launch with different error codes such as 0x887A0006, 0x8887a0005, 0x8887a0007, etc. Although they are somewhat different, most of their solutions will be the same. That’s why we have accumulated all the solutions to fix Apex Legends Engine Error.
The Error Message in the image above is just one example, our solutions are capable to fix every Engine Errors that you may see in Apex Legend.
What is Apex Legends Engine Error?
Before looking at the potential solutions, it is important to know what we are dealing with.
There are different variants of this error. They are.
- Error Code: 0X887A0006, DXGI_ERROR_DEVICE_HUNG
- Error Code: 0x8887a0005, CreateTexture2D
- Error Code: 0x8887a0005, CreateShaderResourceView
- Error Code: 0x887a0007, dxgi_error_device_reset apex legends
More often than not, these errors will appear the moment you launch the game, making the crash. But there have been some instances of this error reported by gamers, where the game stops in between in sessions.
The reason may vary from user to user, but if it is the first time you are playing the game then you need to check the system requirements required to run Apex Legend and make sure that your system is compatible.
But if you are a veteran gamer then the issue can be because of corrupted game files, or outdated Graphics drivers. Other than that, some missing registries can also trigger the Engine Error in Apex Legend.
In this post, we are going to talk about all the solutions in detail and try to fix this issue.
Fix Apex Legends Engine Error
If you want to resolve Apex Legends Engine Error then start by checking for updates. Make sure that your computer is updated. The simple act of keeping your computer up-to-date can resolve the issue, so, update your computer and see if the issue persists.
If it does persist, then use the following solutions to resolve the Engine Error in Apex Legends.
- Fix Missing Registry
- Fix Corrupted Files
- Update Graphics Driver
- Run the game as admin
1] Fix Missing Registry
Let us start by repairing the registry that may be corrupted or is missing. We got you covered as we are going to see how to resolve the issue in this case. Before moving forward, it is highly recommended to create a backup of your Registry.
So, open Notepad and paste the following text there.
Windows Registry Editor Version 5.00 [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\GraphicsDrivers] "TdrDelay"=hex(b):08,00,00,00,00,00,00,00
Now, save the file with the .reg extension. Make sure to change the Save as type to All files while saving the file
Go to the registry file from your desktop, double-click on it to open the file, and click Yes.
Finally, you can open the game and see if it’s working fine.
2] Fix Corrupted Files
If the previous method is to no avail then you are not dealing with a missing registry file. So, the obvious next culprit would be corrupted files, hence, you need to follow the given steps to fix the issue.
- Open Origin.
- Go to the My Game Library > Apex Legend.
- Right-click on Apex Legend and left-click on Repair.
Let the repair run and resolve the issue for you.
3] Update Graphics Driver
Next up, the issue can occur because of outdated Graphics Drivers, especially Error Code 0x8887a0005, CreateTexture2D. But no matter which variant you are stuck on, it is mandatory to update your Graphics Drivers. Therefore, do that and see if the issue persists.
You should also try downgrading to your Graphics Drivers. For some gamers, this has resolved the issue, whereas, for some, it made the crashes less frequent.
4] Run Apex Legends as admin
You need to make sure that you are opening Apex Legends as an administrator. You can right-click on its .EXE file and select Run as admin or just make the game always run with administrative privileges. After doing that, you need to run the game and see if the issue persists.
Hopefully, you are able to resolve Engine Error in Apex Legends with the given solution.
Also read: Fix Apex Legends won’t open on PC
What engine does Apex Legends use?
Staying on the topic of “Engine” in Apex Legends, one may ask, what engine does Apex Legends use? Or does Apex Legends use the Source Engine? Well! If the latter question is what you are asking then you are on the right track. Apex Legends uses Source Engine, but it’s tweaked in such a way that it’s different from other games using the same engine.
How do I fix Apex Legends engine error 0x887A0005?
In order to fix this error in Apex Legends, you need to fix the missing Registry file first. Then, you can fix all the corrupt game files. In some cases, people have solved this issue by updating the graphics driver, which is why it is suggested to do that too. On the other hand, you can run the game with administrator privileges as well.
That’s it!
Read Next: Computer freezes or crashes when closing Programs or Games.
