At times, users may encounter Pisco WiFi login problems. When we try to connect to the router’s interface using the URL https://10.0.0.1/admin in Chrome or Edge, the page can’t be reached. In this post, we are going to see what you can do to fix Piso WiFi login problems quickly.
Fix 10.0.0.1 Piso WiFi Login Problem
If you encounter a 10.0.0.1 Piso WiFi login problem, follow the solutions mentioned below.
- Power cycle your Router
- Clear your browser’s cache
- Reset your browse
- Check if there is any other device using 10.0.0.1
- Try a different device
- Contact your ISP
1] Power cycle your Router
Sometimes, simple steps like restarting your computer can be more effective than complicated troubleshooting guides. Restarting helps eliminate glitches and provides a fresh start. To resolve the issue, turn off your device, unplug all cables, and wait for a moment. After some time, plug the cables back in and turn on the router. Then, restart your device and launch the game. Hopefully, this time you won’t encounter the error.
2] Clear your browser’s cache
Next up, we are going to clear the browser’s cache if it is corrupted is pilling up, you will encounter this issue. Also, your cache stores frequently used items, so, if you power cycle your network device, you should clear the cache to have a clean slate. In order to do so, follow the steps mentioned below.
To clear the cache of the Chrome browser.
- Launch Chrome and then click on the More settings option, which is the three dots at the top right corner.
- Now, click on Settings.
- You then have to go to Privacy and security > Delete browsing data.
- Set the Time range to All time, tick all the checkboxes, and then click on Delete data.
To clear Edge’s cache, follow these steps.
- Open Edge.
- Go to the three horizontal dots and then to Settings.
- Click on Privacy, search, and services, and then select the Choose what to clear button from the Clear browsing data section.
- Set the Time range to All time, tick all the required boxes, and then click on Clear now.
Once done, power cycle your router and then connect to the URL, hopefully, this will do the job for you.
3] Reset your browser
If you have installed some certificates or made some changes to the browser’s settings that are conflicting with the router, you may notice this issue. In that case, our best option should be to reset the browser.
To reset Microsoft Edge, follow these steps.
- Open Microsoft Edge.
- Click on the three dots and then select Settings.
- Go to Reset settings > Restore settings to their default values.
- Click on Reset once the prompt appears.
If you want to reset Chrome, you can use the steps mentioned below.
- In Chrome, click on the More settings option (three dots).
- Click on Settings.
- Now, go to the Reset settings tab, and then click on Restore settings to their original defaults.
Once done, go to the 10.0.0.1 and then try to log in, hopefully, this will do the job for you.
4] Check if there is any other device using 10.0.0.1
You should also make sure that no other devices on your network have a 10.0.0.1 IP address, which is the IP that Pisco uses. When two devices on the same network have the same IP address, it creates an IP address conflict. This conflict means that the network cannot distinguish between the two devices because they appear identical in terms of their IP address. As a result, the devices might fail to communicate properly with the router and other network devices, leading to interruptions in internet connectivity.
5] Try a different device
You should also try using a different device if nothing works for you as this one might have some proxy or VPN configured, if you are aware of that, just disable them. But if you are not, go to 10.0.0.1 on a different device and see if that helps.
6] Contact your ISP
If nothing works, you should contact your Internet Service Provider and ask them to resolve the issue. It seems like there is some issue with your router, which you can do nothing about. So, get your ISP and ask them to resolve the issue.
Hopefully, with the help of these solutions, you will be able to resolve the issue.
Read: Unable to access Router configuration page using login URL or IP address
What is the default login for LPB Piso WiFi?
By default, LPB Piso WiFi credentials are username: admin and password: 12345678. However, if you were asked for different credentials at the time of the setup, you need to log in using them. In case you are unaware of that, contact your ISP for further details.
Read: Can’t connect to this network WiFi error in Windows
What is 10.0 0.1 Piso WiFi time pause?
The 10.0.0.1 Piso WiFi time pause feature allows you to temporarily stop your internet connection without losing the remaining time you’ve paid for. This is useful if you need to take a break but don’t want to waste your internet time. To pause the time, log into the Piso WiFi admin portal using the IP address 10.0.0.1, and click the Pause Time button. When you’re ready to continue, click Resume Time to start using your internet again.
Read: Can’t connect because you need a certificate to sign in WiFi.
