Samsung Flow allows one to connect their laptop to their Samsung Galaxy device and use it nonchalantly. However, there are various connection issues that one faces when using Samsung Flow. Sometimes, Samsung Flow fails to connect to the WiFi or start SmartView, whereas, occasionally, it fails to connect to the smartphone and has Bluetooth connectivity issues, since these issues are related to your network, in this post, we will talk about the solutions that can resolve Samsung Flow Connection issues.
Resolve Samsung Flow Connection issues
To fix Samsung Flow Connection issues, follow the solutions mentioned below.
- Power cycle or reset your router
- Remove the existing user and reconnect
- Clear data and cache of Samsung Flow
- Resolve the Bluetooth issue by switching the connectivity to Wi-Fi or LAN on your PC
1] Power cycle or reset your router
First of all, we are required to power cycle our router. Power cycling the router will clear out glitches that could have caused this issue. To do the same, power off your router, unplug all the cables, wait for a minute, plug the cables back, and turn the device on. Now, check if the connectivity issue is resolved. In case, this didn’t work, you are required to reset your router and check if the issue is resolved.
If you need to reset your WiFi router to the factory default settings, there are two main methods you can use. Some routers have a small pinhole that you can press with a paperclip or similar object to reset them, while others have a dedicated button for this purpose. To find out which method your router uses, consult the user manual that came with it. If you’re not sure how to proceed, you can always contact your internet service provider for further assistance.
Read: How to reset Internet after Power Outage
2] Remove the existing user and reconnect
If there is a glitch due to which the user account is unable to connect to the computer, you can unregister and delete the user and then retry connecting. To do the same, follow the steps mentioned below.
- Launch Samsung Flow on your phone or tablet.
- Sign in to your user account.
- Tap More options (three vertical dots) > Manage devices > Select your desired device.
- Press Deregitser and then on Delete.
Finally, reconnect the user and check if the issue is resolved.
3] Clear data and cache of Samsung Flow
Corrupted app data and cache can be a reason why your Samsung Flow is not connecting, especially if you are trying to connect after a long time. To resolve the issue, we need to clear the data and cache of the application. To do the same, follow the steps mentioned below.
- Open Settings on the Samsung Galaxy smartphone.
- Then, navigate to Apps > Samsung Flow.
- Go to Storage.
- Now, click on Clear cache.
- If the issue persists, clear the cache and then data as well.
4] Resolve the Bluetooth issue by switching the connectivity to Wi-Fi or LAN on your PC
Sometimes, we get “Cannot access Bluetooth device” or “Bluetooth is not available” error messages when trying to access Samsung Flow. This is when there is an issue with your Bluetooth, so, try disabling and then enabling it. If that doesn’t work, run Bluetooth Troubleshooter in Get Help app. But if that too is to no avail, switch the connection to WiFi or LAN.
To change the connection to Wi-Fi or LAN on your PC, follow the steps mentioned below.
- Open the Samsung Flow app.
- Click the three vertical dots in the top right corner, then select “Settings”.
- Look for “Connection method” and click the drop-down menu. Select “Bluetooth”.
- If you prefer to use Wi-Fi or LAN instead, choose the appropriate option from the drop-down menu.
- Now, open Samsung Flow on your phone or tablet.
- Tap More options (the three vertical dots) and turn on Auto Bluetooth to enable Bluetooth when using Samsung Flow.
That’s it!
Read: How to use Samsung apps on Windows 11
How do I reconnect my Samsung Flow?
If you lost connection to Samsung Flow, it’s pretty easy to reconnect. To register your Galaxy phone, open the app and tap on its name in the list of available devices. You will then see a passkey on both devices. Ensure that the passkeys match and click “Ok” on both devices to complete the pairing process. To know more, check our guide on how to use Samsung Flow.
Read: Where to download Samsung NVME Driver for Windows 11/10
Why does my Samsung keep losing Internet connection?
If your Samsung phone keeps losing Internet connection, reboot the device once. Sometimes, network issues can be caused by outdated settings, a damaged SIM card, or software updates, so, you need to keep check them as well and make sure that they are not causing the issue.
Also Read: Samsung DeX not working or connecting.
