This post features different solutions to get rid of Forza Horizon 5 low video memory & low memory issues. Forza Horizon 5 is a popular racing video game available for Microsoft Windows. The game is in the talk due to its high graphics and utterly unique gameplay. However, like any other game, Forza Horizon 5 isn’t free from problems. There are a lot of reports of users facing low video memory & low memory issue in the game. The problem directly results in low FPS in the game. So, if you are also facing a similar problem, try the solution below to get rid of the issue.
Forza Horizon 5 Low video memory & Low memory issue
Below is a list of all the effective solutions to fix the Forza Horizon 5 low video memory & low memory issue.
- Close unnecessary background applications
- Change the Power Plan
- Update the Graphics Driver
- Enable Game Mode
- Adjust the in-game settings
- Turn off Overlay
Now, let’s take a look at all the solutions in detail.
1] Close unnecessary background applications
One of the significant reasons behind Forza Horizon 5 low video memory & low memory issue is unnecessary background running applications. As it turns out, Forza Horizon 5 is a graphics-oriented game; thus, it requires maximum system resources to run without any issues. But if this isn’t the case, i.e, different background applications are consuming system memory, Forza Horizon 5 will be left with limited resources, which will automatically cause the problem in the question. You will have to close all the unnecessary applications to solve the problem. Here’s how.
- Open the Task Manager by pressing Ctrl + Shift + Esc shortcut key
- Right-click on all the unnecessary applications, and choose End task.
Launch the game, and check if the problem persists.
Read: How to increase dedicated Video RAM in Windows
2] Change the Power Plan
The next solution you can try in the situation is to change the system power plan. By default, the power mode is configured to Balanced. The Balanced mode is used to save the battery. But if you want the best performance from your system, you will have to change the power plan. Here’s how to do it.
- Open the Settings by pressing Windows + I shortcut key.
- Navigate to System > Power & battery section.
- Choose the Power mode drop-down option present under the Power section.
- Choose Best Performance mode or activate and use the Ultimate Power Performance Plan.
Now relaunch the game and check if you’re still facing the problem.
Read: Fix Your system is running low on virtual memory message
3] Update the Graphics Driver
Another effective solution in the situation can be downloading the latest graphic driver update. As it turns out, games like Forza Horizon 5 require the latest driver update to run without any problem. If this isn’t the case, you will always find yourself surrounded by issues like low video memory & low memory. So, update the graphics driver and check if it resolves the problem.
See: Fix Total War Warhammer 3 FPS drop, Lag and Stuttering on PC
4] Enable Game Mode
Windows comes with a dedicated gaming mode feature. You can use it to enhance the gaming performance up to a great extent. To enable the feature, follow the below steps.
- Open Settings, and click on the Gaming option present on the left panel of the screen.
- In the following window, select the Game Mode option.
- Enable the toggle present next to Game Mode.
Restart the game, and check if the problem is fixed or not.
Read: Battlefield 2042 FPS Drops and Stuttering Issues on PC
5] Adjust the in-game settings
If your system isn’t capable of running the game in the applied in-game settings, you will most likely face low memory issues. To solve the problem, you will have to make some changes in the Forza Horizon 5 video settings. Below are the settings to apply to get the best performance.
- Lower the resolution
- Set Anisotropic Filtering to low/medium.
- Set Shadow quality to low
- Disable Nigh shadows
- Put Blur quality to low
- Environmental texture quality to medium/ low.
- Anti-Aliasing MSAA – 2x
Read: How to increase Virtual Memory in Windows
6] Turn off overlays
The next solution you can try is to disable Overlay on Steam. You can do it by following the below steps.
- Launch the Steam client on your Windows PC.
- Click on the Library option.
- Right-click on Forza Horizon 5, and from the context menu, choose the Properties option.
- In the General tab, disable the Enable Steam Overlay while in-game option.
That’s it. Launch the game, and you will see that you are no longer facing the problem.
Read: Fix FIFA 22 FPS Drop and Increase FIFA Performance
Why is Forza 5 Choppy?
If Forza Horizon 5 is choppy or lagging on your Windows PC, the possibility is high that you haven’t downloaded the latest game patch update. Download the update and check if it resolves the problem. The issue can also occur if your system doesn’t feature the latest graphics driver update.
Read: Fix High Disk & Memory Usage when playing Games
What are the minimum requirements for Forza Horizon 5?
Here are the minimum requirements to run Forza Horizon 5 on Windows PC.
- OS: Windows 10
- Processor: Intel i5-4460 or AMD Ryzen 3 1200
- RAM: 8 GB RAM
- GPU: NVidia GTX 970 or AMD RX 470
- DirectX: DirectX 12
- Free storage: 110 GB of available space
