This post will show you how to check the Xbox Controller Battery on your PC. Xbox controllers are input devices designed by Microsoft. They are also compatible with Windows PCs and offer a very reliable gaming experience. However, it can be frustrating if your controller runs out of juice during intense gameplay. Well, no worries. Keep reading this post to learn how to check the Xbox Controller Battery on your PC.
How do I charge my Xbox One controller on my PC?
To charge your Xbox One controller with your PC, plug a micro-USB charging cable into the top of the controller and plug the other end into your PC. This will start charging your controller. However, if using an Xbox Series X|S, Elite Wireless Controller Series 2, or the Xbox Adaptive Controller, connect it using a USB-C cable.
How to check Xbox Controller Battery on PC?
To check the Xbox controller battery on your PC, click on the Xbox Button on the controller to open the home screen
You will see the battery level indicator at the bottom right corner. Besides it, you will also see the time.
When your Xbox Controller is plugged in via USB, you will also see a plug over the battery icon. However, the battery level won’t show when the controller is plugged in.
Alternatively, you can check the controller battery level using the Xbox Game bar. Here’s how:
Press Windows + G to open the Xbox Game Bar.
A widget will appear in the sidebar and display battery info for detected controllers.
If the widget isn’t visible, click the + icon to add it.
I hope these steps help you.
Read: Xbox Elite Controller input lag on PC
Why is my Xbox controller blinking?
If your Xbox controller is blinking, check if the batteries are fully charged, or try removing them and then putting them back in. However, if that doesn’t help, try re-syncing the controller and checking for hardware damage.
How long will the Xbox controller battery last?
The Xbox controller battery lasts 30 to 40 hours of gameplay when fully charged. High-quality AA batteries or the official Xbox rechargeable battery pack can ensure optimal battery life. Regular usage and battery quality can affect the duration.
Is it bad to leave your Xbox controller charging overnight?
Yes, you can leave your controllers on charging overnight. The charging will stop once the batteries have reached full charge and will display a green glow indicating a full charge.
