If you experience low headset volume on Xbox, the solutions provided in this article may help you fix the issue. The users who experienced this issue reported that despite setting their headsets to the maximum volume, they were not getting the desired sound output. Some users connected another headset but to no avail. Incorrect audio settings in Xbox and outdated firmware are some of the possible causes of this issue.
How to fix Low Headset Volume on Xbox
The following solutions will help you fix the low headset volume issue on Xbox.
- Adjust your headset volume in Audio Settings on Xbox Console
- Update your Xbox Controller Firmware
- Check your Speaker audio settings
- Run the Audio Setup Tool
1] Adjust your headset volume in Audio Settings on Xbox Console
By default, the headset volume is not set to maximum in Xbox Console. Due to this, you will not get the desired sound output on your headset after connecting it to the Xbox Console. To fix this problem, you have to increase the headset volume in Audio Settings on your Xbox Console. The following steps will help you do that. Before proceeding, connect your headset to your Xbox Console otherwise, you will not see the Audio settings option in Xbox Guide.
- Press the Xbox button to open the guide.
- Navigate to the Audio tab. You will find it at the bottom right side of the Xbox Guide.
- Now, you will see the Headset Volume option. Move the slider to the right to increase your headset volume.
In addition to the Headset Volume, you will see two more options there.
- Headset Chat Mixer: This feature lets you control your Game audio and Party Chat audio. If you want the Game louder than the Party chat, move the slide to the left, and if you want the Party Chat audio louder than the Game audio, move the slider to the right.
- Mic Monitoring: It is the feature that enables you to hear your own voice through your headset. If you do not want this feature, move the slide to the left.
2] Update your Xbox Controller Firmware
If the issue persists after increasing your headset volume in Xbox Console Audio settings, you should update your Controller Firmware. You can connect your wired headset to the Xbox Controller by plugging it into the 3.5 mm audio jack or via the Xbox One Stereo Headset Adapter. If the firmware version of your Xbox Controller is not up to date, you will experience audio issues. Hence, keeping the firmware of your Xbox Controller up to date is recommended.
The following steps will help you update the firmware of your Xbox Controller.
- Press the Xbox button to open the Guide.
- Go to “Profile > Settings.”
- Select the Devices & connections category from the left side and then click Accessories.
- Now, click on the three dots and then click the Firmware version.
- Click Continue to install the available updates.
3] Check your Speaker audio settings
This solution is for the users who have connected their TV to Xbox Console through HDMI cable or speakers through Optical cable. If you are not receiving the desired sound output, make sure that your HDMI or Optical audio is set to Stereo uncompressed. The following steps will guide you on this.
- Open the Guide by pressing the Xbox button.
- Select the General category from the left side.
- Click Volume & audio output.
- Under the Speaker audio section, select Stereo uncompressed in HDMI audio or Optical audio (whichever you are using).
If the Speaker audio section is greyed out, set the Headset format to Stereo uncompressed (see the above screenshot).
4] Run the Audio Setup Tool
The Audio Setup Tool will help you troubleshoot audio issues on your Xbox. Follow the steps written below:
- Go to “Profile & system > Settings > General > Volume & audio output.”
- You will see the Audio setup option under Advanced. Select it.
- Highlight the audio setup option that you want to use and then press the A button to start the audio test.
The above steps will help you know whether your speakers are working fine or not.
Read: Error 0x800488FC when you sign in to your Xbox One console.
Why is my headset volume so low on Xbox One?
Your headset volume is low on Xbox One because of the low volume in Xbox Audio settings. By default, the volume of the headset or speaker is not set to maximum on Xbox. Due to this users get low volume output on Xbox One despite setting their headsets or speakers to the maximum volume. Another cause of this issue is outdated firmware. In this article, we have explained the methods to troubleshoot this issue on Xbox Console.
How do I make my volume louder on Xbox One?
To make your headset or speaker volume louder on Xbox One, open the Audio settings on your Xbox Console and then select your headset or speaker. Now, move the slider for your headset or speaker volume to the right to make the volume louder. In addition to this, you can also adjust the Headset Chat Mixer and Mic Monitoring settings.
We hope the solutions explained in this post helped you resolve the issue.
Read next: Xbox Remote Play not connecting or working.
