If you get Input Signal Out of Range, Change settings to [resolution] or Change Mode to [resolution] error on your monitor, here is how you can fix the issue. Whether you have a dual or single monitor setup, you can use this tutorial to fix the issue within moments.
Although it is a rare issue on Windows computers, it may happen to you when you have a faulty graphics driver or something else. It could also happen if the screen resolution you set is higher than the screen resolution supported by your monitor. For example, if your monitor supports a maximum resolution of 1366×768, but your graphics card supports 1920×1080 resolution, and you change the screen resolution to that size using your graphics card, then you may get this error.
Two situations could occur along with the error message—you can use your monitor and lose the connection frequently, or you cannot use the monitor at all. If you are a victim of the second situation, you need to create a bootable USB drive of Windows 11/10. However, using your computer, you can change the resolution using the following guide.
Fix Input Signal Out of Range, Change settings Monitor error
To fix Input Signal Out of Range, Change settings error, follow these steps:
- Change resolution in Safe Mode
- Reinstall graphics driver
1] Change resolution in Safe Mode
It is the only solution you can use to get rid of this problem. However, if you use a dual-monitor setup and one of the monitors shows such an error message, you do not need to boot your PC into Safe Mode. In that, you can follow these steps to change the monitor resolution:
- Go to System > Display.
- Choose the defective monitor.
- Head to the Display resolutions section.
- Choose the correct resolution from the drop-down list.
After that, you should be able to use the monitor without any problem.
However, if you have a single monitor setup and the error message appears on the monitor, you need to boot your computer into the Safe Mode first. For that, do the following:
- Go to System > Recovery.
- Click the Restart now button under the Advanced startup.
- Go to Troubleshoot.
- Click on the Advanced Options > Startup Settings > Restart.
- Choose the 4th option or press the 4 key.
On the other hand, if you cannot start or use your computer, you need to create a bootable USB drive first. Then, click on the Repair your computer and follow the same steps as above to boot your computer into Safe Mode.
Once you are in Safe Mode, you can follow the aforementioned steps to change the screen resolution. Once you have done this, you will be able to use your monitor without any problems.
2] Reinstall Graphics driver
A faulty graphics driver could cause this issue on your Windows computer. Whether it is the NVIDIA driver or some other, your graphics driver could be the reason for this issue. Therefore, it is recommended to uninstall the graphics driver and reinstall it to check if it resolves the issue or not.
That’s all! I hope this guide helped.
Related: Fix Acer monitor no signal issue.
Why is my monitor saying Input Signal not found?
If your monitor displays an “Input Signal not found” message, it implies that there are some issues with the connector cable. Whether you use an HDMI, VGA, or DVI-D cable, you can experience the same error when using a monitor with your computer. The cable might be loose, so you should reconnect it.
How do I fix my monitor Input Signal Out of range?
To fix a monitor input signal out of range problem adjust the computer’s resolution to a compatible setting with the display. You may need to reboot the computer or use a different monitor to make these changes.
Related: Fix Generic PnP Monitor not detected problem on Windows.
