Do you encounter issues with the Intel driver often? Several users have reported instances where the Intel Graphics settings crashed. It mainly occurs when the users want to access the settings, leading to its unusable state. The frequent crashing of the Intel software causes interference with the system’s OS. That is why it is vital to know the causes that can lead to such an error. This post will talk about Intel Graphics Settings, the causes behind its crashing, and possible solutions.
What is Intel Graphics Settings?
Intel Graphics settings are the choices that enable users to make changes in the graphics control panel of Intel. You can optimize the options to enhance the gaming performance of the PC. It is also called Intel Graphics Command Center offered through the Microsoft Store. Apart from gaming, you can customize manage connected display, scaling, video modes, and setup anti-aliasing.
Possible reasons why the Intel Graphics Settings software is crashing
Various reasons can indicate why the Intel Graphics settings crashed. Take a look:
- Out-of-date drivers: It is essential to understand that drivers need to be updated regularly. That is the only way to ensure that the driver performs efficiently. Out-of-date drivers lead to malfunctioning of the software. It can lead to the development of such an error.
- Corruption errors and bugs: Windows can get affected by bugs and glitches despite best efforts. That will lead to the occurrence of such issues. Here, the potential solution is to run Windows’s troubleshoot options as built-in features.
- Issues with the intel driver: The problem may lie with the Intel driver. Corruption of the software is not impossible. Incompatibility of the old drivers or the presence of corrupted drivers can cause such errors in the Windows operating system. You need to install the latest driver and check the compatibility to resolve the issue.
Intel Graphics Settings keep crashing
If your Intel Graphics Settings keep crashing on Windows 11/10 computer, take a look at the fixes listed here:
- Reinstall the Intel Graphics Driver and Intel Display HDMI/Audio Driver
- Update or Reinstall the Intel Software
You will need admin permission to execute the suggestions.
1] Reinstall the Intel Graphics Driver and Intel Display HDMI/Audio Driver
- Hold Windows and X keys at the same time to open Device Manager.
- In Device Manager settings, search and expand Display Adapters.
- Look out for Intel Graphics Driver or anything with a similar name. Alternatively, your system can also have Intel Graphics Media Accelerator Driver (Intel GMA Driver).
- Right-click on Intel Graphics Driver.
- Select Uninstall option from the context menu.
- Tick-mark Delete the driver software for this device.
- Restart the PC.
After this, you must also uninstall the Intel Display HDMI/Audio Driver. Take a look at the steps you must follow:
- Press and hold Windows and X keys simultaneously to open Device Manager.
- Search for Sound, Video, and Game Controllers. Expand the option.
- Look out for Intel HDMI Display Audio. Alternatively, you can also find Intel Display Audio.
- Click on Uninstall from the drop-down menu.
- After the process is finished, restart the PC.
Now that the uninstallation is done, you must reinstall Intel Graphics Driver and Intel Display HDMI/Audio Driver. There are two distinct methods that you can follow.
The first method involves the usage of Intel Driver & Support Assistant. It will detect and then reinstall the driver automatically. You don’t have to do anything here.
In the second section, you need to follow a series of steps:
- Identify and write down the Intel Processor and the Intel Processor number
- Open the Download Center. Here, type the processor number and press enter
- On the left-hand side, under the Filter By section, tick on Drivers
- After that, select the driver you want to reinstall. Make sure that you choose the latest updates.
- Click on the Driver. Select the Download option
- Once the download is finished, click and launch the Exe file
- After the installer instructions get displayed, click on Begin Installation. Follow the instructions and wait till the installation is complete
- Run the Exe file. Now, you need to verify the driver is installed
- Press and hold the Windows and X keys followed by M to open Device Manager
- Search for Display Adapters and double-click on it. Click on the Intel Graphics device
- Go to the Driver tab. Now, see that the Driver Date and Driver Version has the correct information.
Related: How to fix Intel Graphics Drivers problems?
2] Update or Reinstall the Intel Software
You can follow these steps to reinstall the Intel software. Take a look –
- Open Microsoft Store.
- Click on the Get button that you will find on the right-hand side.
- You need to sign in if you are not logged in. A pop-up message will appear saying Open Microsoft Store. Click on that to proceed further.
- Click Get to initiate the installation of the Intel Graphics Command Center in the Microsoft Store application.
That is it; this is how you can update or reinstall Intel Software following the above steps.
Read: Display Driver Uninstaller lets you uninstall AMD, INTEL, and NVIDIA Drivers completely.
Intel is one of the most well-known graphic drivers in the industry. With exceptional performance, the Intel driver handles the OS and gaming aspects of the PC efficiently. However, some users might encounter the crashing of the Intel Graphics settings while accessing it. You need to assess the various causes and apply the solutions mentioned above.
However, if that doesn’t work, it is advisable to opt for the assistance of a professional.
Why is Intel Graphics Control Panel missing?
Updating the DCH graphics driver can lead to the missing of the Intel Graphics Control Panel. That is because the Intel Graphics Command Center has replaced The Intel Graphics Control Panel. It is primarily for systems having the 6th Generation Intel processors or above versions.
Why is Intel Graphics Settings Option Missing from the Right-Click Context?
It can be because the missing registry values are missing or outdated Intel HD Graphics card software. The software installation may sometimes be incorrect, or the menu needs to be enabled from the software settings.
Why does my graphics driver keep crashing?
There could be many reasons, but one primary reason is a corrupt or incompatible graphics driver on your PC. It is advisable to uninstall the graphics driver and let Windows search and find the compatible one that is the latest.
