OneNote is a great note-taking app that allows multiple users to collaborate on a single project. If your team is working on something together, a template would be handy to start the project quickly. Therefore, you can check out this article to find the best and free OneNote templates for project management and planners.
How to install OneNote templates
There is no download link for any OneNote template as they come with the app. If you have downloaded the OneNote app, you can install any of the following templates within moments. to install OneNote templates, follow these steps:
- Open the OneNote app on your computer.
- Open a notebook you like.
- Go to the Insert tab from the top menu bar.
- Click on the Page Templates option.
- Select the Page Templates option again.
- Expand the category of the template from the right side.
- Click on a template you want to preview and install.
Now, you know how to install any OneNote template within moments. That said, you can check out the following template to fulfill your purpose.
OneNote Templates for Project Management & Planners
The best and free OneNote Templates for project management and planners are:
- Simple To Do
- Prioritized To Do
- Project To Do
- Project Overview
- Detailed Meeting Notes
To learn more about these templates, continue reading.
1] Simple To Do
As the name denotes, Simple To Do is a minimalist to-do list maker that helps you plan meetings, projects, or anything else in a simpler form. Whether you need to add a date to the list, enter a checklist, bullet point, or anything else, you can include almost everything without any error. The background is quite cool and not distractive. The best thing is that it comes with some checkboxes, which are clickable. For your information, you can find this template in the Planners section.
Read: Best OneNote Templates for Work
2] Prioritized To Do
If you need a template where you can prioritize your tasks, this OneNote template is for you. You can find three different columns where you can note down your tasks one after one after the urgency and importance. Like the first template, you can find checkboxes so that you can tick a task that has been done. Once the template is installed, you can start writing your tasks in the respective columns. Install this template from the Planners section.
Read: Best OneNote Templates for Meetings
3] Project To Do
When you want to manage a project, it is mandatory to list down your tasks and write additional notes so that you can plan that thing in the future. If you do the same, this template would be an excellent option for you. It helps you plan multiple projects and take notes as you want. It offers a separate section where you can write your messages as per the tasks. You can find this one in the Planners tab like the above two templates.
4] Project Overview
If you want to plan a project with your friends or team members, it is handy to write almost everything, including the project name, company name, goals, resources, schedules, etc. If you want to go into detail, this OneNote template is one of the best things you can install. As it doesn’t have anything in the background, you won’t get distracted or don’t need to change anything. To install this template, you need to head to the Business tab.
5] Detailed Meeting Notes
Let’s assume that you want to organize a meeting or conference with your team members to discuss something. In every meeting, you have something in common. For example, date and time, location, agenda, announcements, attendees, etc. If you want to have a OneNote section where you want to write everything in detail, this template will be handy for you. Like the aforementioned template, you can find it in the Business tab.
How do I create a template in OneNote?
To create a template in OneNote, you need to switch to the Insert tab and click on the Page Template button. Following that, select the Page Template option and add all the elements you want to add to a template. Then, click the Save current page as a template option.
That’s all! Hopefully, these OneNote templates will fulfill your demands.
