In the quest to make your Touchpad work according to your requirements, we will see how you can turn on or off Press the Lower Right Corner of the Touchpad to Right-click in Windows 11/10.
Turn On or Off Press the Lower Right Corner of the Touchpad to Right-click in Windows
To Turn On or Off Press the Lower Right Corner of the Touchpad to Right-click in Windows 11/10, you can use any of the following methods.
- Using Windows Settings
- Using Registry Editor
1] Using Windows Settings
Let us start with the simplest of the two. We will see how you can disable the option as it is enabled on your system by default. Windows Settings is a graphical interface where you can disable the feature in question with just one click. If you want to do the same, follow the prescribed steps.
- Open Settings either by searching it out of the Start Menu or by keyboard shortcut Win + I.
- Go to Bluetooth & devices.
- Click on Touchpad.
- Expand Taps and then untick Press the lower right corner of the touchpad to right-click to disable it.
Close Settings, and you will notice that pressing the lower corner of the touchpad doesn’t right-click now.
If you want to enable it again, go to Settings > Bluetooth & devices > Touchpad > Taps and check Press the lower right corner of the touchpad to right-click option. This will disable the feature for you
It is quite easy. Isn’t it?
2] Using Registry Editor
Now, let us use the tools for tech enthusiasts. Registry Editor is an app on your system that contains registries, you can configure them to customize your computer. Registry Editor is a better option for customization as it has more options, however, the only caveat is that there is very little room for error. That is why we recommend you create a backup of your registries before using it to change your right-click option.
Once you have created a backup, open Registry Editor by searching it out of the Start Menu and go to the following location.
Computer\HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\PrecisionTouchPad
Look for RightClickZoneEnabled. If you can’t find the value, right-click on the PrecisionTouchPad key and select New > DWORD (32-bit) Value.
Name it RightClickZoneEnabled. Now, open the newly created DWORD value and set its Value data to 0 to disable the option.
To enable it, launch Registry Editor, go to the location mentioned earlier, open the RightClickZoneEnabled and just set the Value data to 1 or ffffffff.
This will do the job for you.
Read: Touchpad getting disabled automatically in Windows
How do I turn off touchpad clicking Windows 11?
Touchpad clicking or Tap to Click is a feature of Windows 11/10 computers. With this enabled, you don’t have to click on a particular spot on your touchpad to select something; instead, you can just tap on the touchpad to have the same effect. However, some users find this annoying as it makes their touchpad prone to accidental clicks. In this case, you can disable Touch to Click using this guide.
Read: How to Turn On or Off Tap Twice and Drag to Multi-Select on Touchpad in Windows
How do I enable my touchpad to right-click?
Right-clicking on the Touchpad is enabled by default. If it is not working on your system, then there is something else you need to take care of. If you want to resolve the issue, we recommend you check our guide on what to do when Touchpad right-click is not working. Hopefully, those solutions will do the job for you.
