If you trying to install a 16 bit DOS application on Windows 32 bit PC then you may encounter an error – The system file is not suitable for running MS-DOS and Microsoft Windows applications. In this article, we are going to fix this issue with the help of some simple solutions.
These are the notifications you will receive if you are dealing with this problem.
“16-bit MS-DOS Subsystem
C:\Windows\system32\cmd.exe
config.nt. The system file is not suitable for running MS-DOS and Microsoft Windows applications. Choose ‘Close” to terminate the application.”
path to the program that you are trying to run or install
C:\Windows\System32\config.nt The system file is not suitable for running MS-DOS and Microsoft Windows applications. Choose ‘Close’ to terminate the application.”
C:\Windows\System32\Autoexec.nt The system file is not suitable for running MS-DOS and Microsoft Windows applications. Choose ‘Close’ to terminate the application.”
These are two things you can do to fix this error.
1] Change Variable Value
There are some MS-DOS programs that won’t work if the filename path of Environment Variables is too lengthy. Therefore, to fix the issue, we are going to assign a shorter file path value to the same.
To do that, launch Run by Win + R, type the following command, and hit Enter.
systempropertiesadvanced
Make sure, you are on the Advanced tab and click Environmental Variable > TEMP > Edit.
Paste the following location in the Variable Value section and click Ok.
C:\Windows\Temp
Now, select TMP from the Environmental Variable and click Edit.
C:\Windows\Temp
Now, retry installing the software that was causing you the trouble.
2] Re-generate required files
Another reason for this problem is that the following files are either corrupted or missing.
- Config.nt
- Autoexec.nt
We are going to create new files of “Config.nt” and “Autoexec.nt” and place them in the correct location.
For Config.nt, open Notepad and paste the following text.
dos=high, umb device=%SYSTEMROOT%\system32\himem.sys files=40
Now, click File > Save as. Go to the following location, change “Save as type” to All Files, name the file “config.nt”, and click Save.
C:\Windows\System32
For Autoexec.nt, open Notepad and paste the following text.
@echo off lh %SYSTEMROOT%\system32\mscdexnt.exe lh %SYSTEMROOT%\system32\redir lh %SYSTEMROOT%\system32\dosx SET BLASTER=A220 I5 D1 P330 T3
Now, click File > Save as. Go to the following location, change “Save as type” to All Files, name the file “autoexec.nt”, and click Save.
C:\Windows\System32
Now, restart your computer. Hopefully, these solutions will fix the “The system file is not suitable for running MS-DOS and Microsoft Windows applications” error.
Read next: Fix Invalid MS-DOS Function file error.
